Let me start by stating what I have done so far to my son's zinger since I started having flooding/carb problems.
After going through the carb countless times I bought another used carb. I drilled the plugged exhaust after reading a thread about it on here. New plug, no air filter. Still had flooding, starting problems though it would start and run after sitting overnight.
When I put the new/used carb on I used the bowl off the original carb since it was cleaner.
I bought an aftermarket air cleaner/filter that clamps right on the carb. I checked the manual and noticed the plug that had been in the motor wasn't the right NGK plug. It is supposed to be NGK BP6HS. The parts store only had the "crossover" which is an Autolite 4123. Can someone confirm this? Now this plug is shorter than the NGK plug that was in the motor.
I dumped the gas tank out and put fresh gas in it. I put the other carb bowl on after cleaning it real good including the little starter jet thats in the bowl. I noticed the drain bowl outlet nipple was slanted up about a 30 degree angle. Installed the new air filter, new plug and confirmed it was getting fire. Turned the gas on. WON'T START. Put old NGK plug back in, same thing.
The carb doesn't leak anymore, but I can't get it to start.
I was going to check the Reeds but to get to them I'm going to have to pull the motor out and I don't want to have to do that unless the majority of the replies think that it is a reed problem.
I'm stumped fellas. I don't know what else to do. I need advice.
That would be pretty damn funny
