Thread: 200x gasket kit and internals ?s
    tyman's Avatar
    tyman is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2006
    Bedford, Pennsylvania
    458
    Hey... My dad's 86 200x died today... locked it up... the drive gear went up between the ?clutch gear? and something else and the chain got stuck between 2 drive gears... only thing that was VISIBLY damaged was the oil drive chain, oil pump, and the oilpump gear... anything we should check for damage??? anything else that would be a VERY GOOD idea to replace because it may have been weakened by this incident???
    Whats the difference between the Pro-x Piston and the Wiseco Piston that Dennis Kirk offers???? Any advantages??? Downsides??? Are the rings from either piston identical or can be substituted on the stock piston???
    Also, what does the Vesrah Complete Gasket Kit come with??? does it come with the side cover gaskets??? what seals does it have??? thanks for any/all help
    tyman
    EDIT: on a side note, how hard is it to install new seals/boots in front forks on an 86 200x???
    86 200x
    72? US90
    79 ATC70
    83 ATC70
    84 ATC70
    Howdy's Avatar
    Celina, Ohio
    10,079
    A friend of mine had this same problem. He had to replace the cam, rockers, and such. This was because the top end was starved for oil. On his we found out the one metal plate down by the oil pump had been removed and lost ( before he got the machine ). I would check the top end to be sure you don't have any damage.
    Howdy
    tyman's Avatar
    Jul 2006
    458
    mmkay.. will do.... sounds like a good time for a topend rebuild anyhow...
    86 200x
    72? US90
    79 ATC70
    83 ATC70
    84 ATC70
    Nov 2002
    Kirkville, NY
    3,831
    I have not bought a 86 200x kit but all the other Versa kits I have bought have come with valve seals, all o-rings, and all gaskets (provided you get the full kit not the top end kit). They do not come with the press in oil seals (kick start shaft seal, shifter shaft seal, ect.)
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    tyman's Avatar
    Jul 2006
    458
    hey... did your kit come with gaskets like the side cover gaskets??? because were ordering those gaskets off service honda cause we thought it wouldn't come with them...
    86 200x
    72? US90
    79 ATC70
    83 ATC70
    84 ATC70
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by tyman View Post
    Yes, as long as you order the full kit not the top end one. It comes with all the gaskets you need.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
