First off, a 82R rear axle is NOT a direct bolt on. It has a different sprocket hub which must be swapped with a 200X sprocket hub.
The following post is looking at the axle as if you were behind the trike or as shown in the photo.
So, I got off the old 250R sprocket hub with a cut off wheel and it appears that it is properly removed towards the left side of the axle or away from the axle nuts. BUT, if thats the way it comes off then when you tighten the axle nuts I would imagine it could force the sprocket hub off towards the left. Unless it is a severly tight fit, I don't see why it comes off to the left or sprocket side of the ATC, I would think it should come off towards the axle nuts. There are no clips or anything else holding it in place other than the splines themselves, and no "shoulder" that I see either.
Now I need to get off the 85 sprocket hub and press it onto the 82R axle. Before I heat this thing up and put it in a press, could someone please tell me which direction this hub is intended to be pressed off if they were looking at the 200X from behind. And if it does press of towards the left, what the heck keeps it on the axle when the axle nuts are tightened?
Is it that strong of a press fit that it relys on that alone? Doesn't make sense to me. Thanks for any help!! I gotta get this fixed for my bud....
