Thread: Chain slack?
    Mar 2007
    Minnesota
    102
    Chain slack?
    Hey all,
    I have a 1984 YTM200L chain drive and am wondering how much slack I should have on my chain. I'm measuring about 1 to 1 1/2 inches right now.
    Too much? Too little? Any benifits to having it a little tighter? I would just hate to see it fall off some day and get caught behind the front sprocket and crack my case...
    ColeTrickle's Avatar
    ColeTrickle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    New Hampshire
    247
    Is that rig a hardtail? if so 1" is good. If you have rear suspension on that you'll want to run a little more. 1 1/2" or so. Also watch the chain as you spin the rear wheels, (on stand) and check for loose or tight spots. That will give you a good idea of the condition of the chain and sprockets. good luck!
    Mar 2007
    Minnesota
    102
    Yeah its a hard tail. Another thing is, I just bought a new chain. I noticed two main types; ones with o-rings and ones without. I bought the chain without o-rings.
    Bad idea? Whats the difference? Just lube?
    Mar 2007
    New Hampshire
    247
    the standard chain is lighter and generally not quite as strong. The light factor is important with smaller engines. The o ring chain is lube injected then sealed buy the o rings, much better, but puts more drag on engine. O ring last much longer, and costs more. Good luck, DRaCuLa
    Mar 2007
    Minnesota
    102
    Thanks for all the replies!!
    So do you think I made a mistake in purchasing just a regular old chain? Just wondering if I should buy a good one or not...
    Mar 2007
    Williamsport, PA/Lycoming county
    829
    I usually don't bother with the sealed O-ring chains. Just keep it lubed and your good to go. Theres no need to run out and get the sealed one when have a chain that with a little more maintaining, aka frequent lubes, will last a long time. If you have the money next time and you ride in sand, silt, or mud bog go for the o-ring chain. i personally mud a lot and still use a non o-ring chain.
    My Stable:
    2007 ARCTIC CAT DVX400
    07 Kawasaki Ninja 650R--My Baby--
    Honda 200M with a 200E engine and 200S front end- A true stump puller SOLD!
    Scars are a reminder to the old of all the dumbshit they did while young - Me
