hey guys im wondering if the petcock in the picture is in the on position or in the reserve position? thanks
when in doubt throttle it out
old ride 2002 GSXR 1000
new ride 1985 TRI-Z 250
.070 over - boysen reeds - head redone
2001 dodge ram "off road" (toy hauler)
all these tri-z experts and no one knows?
wait a little while longer... sometimes simple answers take hours....
86 200x
72? US90
79 ATC70
83 ATC70
84 ATC70
That would be the on position homeboy.
on the ring around it with the two tiny screws it tells you on,off,reserve
The longer part of the lever is what its on just like the smaller one.. so right now in the pic its on reserve,,pointing down is ON and in the middle is off![]()
Reserve.![]()
My Stable:
2007 ARCTIC CAT DVX400![]()
07 Kawasaki Ninja 650R--My Baby--![]()
Honda 200M with a 200E engine and 200S front end- A true stump pullerSOLD!
Scars are a reminder to the old of all the dumbshit they did while young - Me
the only letters i cans see is reserve the others faded or got scraped away.
i see that im not the only one who is confused! lolkeep it coming ill take the majority i guess
Can I ask a queston Erikb45..
I see you also have the second switch there.. does yours have to be pushed inwards a bit first before you can turn it? That's how mine is and I was just wondering if I put it back together correctly or if mine is messed up?
thanks!
chris its worn out and soon will start to leak
Its funny cause i always had difficulty trying to remember which was reserve and which was on. I used to look at the other bikes i rode with to make sure it was the same.![]()
glad to see others had issues too.
'86 Tecate
'85 ATC 250R
'85 Tri-Z
'87 ATC 200x
'85 ATC 250R - Rider
'86 Tecate - Rider
I wondered the same thing until I ran out of gas and turned it around. Now I can tell when it's starting to run out then go to reserve right away while going, that way I don't have to kick it a million times to get the fuel going again. I don't let it run all the way out, just listen for when it's getting lean.
Man I'm really having a problem with this site, I need to get some work done!
any tips on how to slow down a bit would be greatly appreciated![]()
Im 110% positive on what I said before..I checked both my bikes and 4 other pumps.. it even says that in the service manual,Witch I know you all have![]()
It depends on how it was put back together. You can put the lever in backwards and they will actually be reversed because of how the backside of it is setup. I believe stock is like Raffa said but mine is reversed cause I put it back together wrong :P
or another possibility is that the lines comeing from the tank are switched.. I dont think it can go together backwards...
If you put it with the short end pointing the opposite direction of how it is stock (which I believe is towards the front) then it would be different.
