Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 42
Thread: Hondaline Hartmans 300R ICE Racer build
    got the parts I needed today from bruce to go ahead and start the build!
    WHO Knows witch way the rings go,,,I know the N on the ring goes up but witch is the top and the bottom? theres a little lip on each ring and it says not to interchange the top and bottom...
    with the N faceing up on both the lips could face each other in the middle,,OR one could face down and one face up..
    Attached Thumbnails Attached Thumbnails 100_2422.JPG   100_2423.JPG   100_2425.JPG   100_2426.JPG   100_2427.JPG   100_2428.JPG
    Im stuck here till i get the ring issue figured out
    Hey kintore rember that old ice racer you picked up for bruce? Thats what this is going in!!
    Attached Thumbnails Attached Thumbnails 100_2429.JPG   100_2430.JPG   100_2431.JPG   100_2432.JPG   100_2433.JPG   100_2434.JPG
    Jul 2006
    whats the problem with the rings?
    im looking at my piston right now
    there is a lip on each ring on the outside witch way are they faceing
    one lip is on the N side and the other is on the bottom of the N side
    Jul 2006
    I dont see a lip on mine
    Its real tiny pull the ring off and look
    Jul 2006
    i did.... I dont see a lip any where on the ring
    dam Honda! bahahahhahah
    Jul 2006
    i can tell you one thing the ring size thats stamped near the end faces up
    yes I know the stamp is up allways!
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    Are you saying the rings have a notch that goes around the locating pin in the piston, or that the rings thicker on the outside edge than the inside one?
    Any way to get a pic, or two?
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Jul 2006
    theres a minor lip on the outside of the ring that is critical to how it runs, the bottom goes (stamp up lip down) the top is ( stamp up lip up)
    thanks syko for clearing that up.. the lip on the top ring faces up with the stamp up, and the bottom ring the lip faces down with the stamp up..its a real tiny lip on the outside of the ring that go's all the way around,,I tryed to get a pic but was unable to,,Just glad I caught it with my EYE!
    Ontario, Canada
    457
    Bryan, could you tell me what the size of your piston is and where you got your rings from oh and the $ involved in getting me some rings? lol i'm pretty sure my 300R is in need of some fresh rings, but i think mine is stock bore?
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    his is a stock bore also and Ill see if he can, the 300r kit was on a 83-84 motor when he bought the complete motor and was said to be a fresh piston and rings,,but when I build I like to put all fresh in.. I got 2 motors from him a 83-84 and a 81-82 took them both completely apart and used the internals of the 83-84 with the 81-82 cases and shift shaft because its going in a 82 frame and needs the longer shift shaft..Im not quite shure what he spent, he had a lot of the parts and spent over $100 at service honda,,Im shure when he read's this he will clairify that aspect.
