Results 1 to 15 of 18
Thread: powder coating removal?
    Aug 2006
    NW Ohio
    1,043
    how do i remove powder coating from my250r fram and swinger? ive tried blasting and all it did was dull it. will an acid dip work? anyone know? any places around NW ohio that acid dip. need to know like yesterday so please if you know anything or have a suguestion please dont hesitate to post. thanks in advanced!!!
    ATC500AF
    Sep 2005
    Missouri
    469
    If it is a small area you can use a torch and burn it off. I have had frames that were powdercoated that needed to be welded, the fastest way was to burn the powder off, then weld it up. Maybe that will help.
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    Not real sure if it will work on powdercoat, but you could try Aircraft Stripper.
    It takes almost anything off of metal. You can get it at Walmart, or any parts or hardware store.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Phoenix, AZ.
    6,719
    Quote Originally Posted by InPiEcEs View Post
    That's what I used to remove the powder from the steering stem on my 70. That and a razor blade.
    Jul 2006
    western ny
    3,366
    Aircraft Stripper is awesome as hell. i use it for everything and seems to work. i did learn not to let it sit on fiber glass for a long time lol. as said above it take almost anything off metal.
    good luck man
    GIT IT RAAAGGGGG !!!!
    Mar 2007
    Williamsport, PA/Lycoming county
    829
    Just curious but why are you REMOVING the powder coating? Going for the polished look?
    My Stable:
    2007 ARCTIC CAT DVX400
    07 Kawasaki Ninja 650R--My Baby--
    Honda 200M with a 200E engine and 200S front end- A true stump puller SOLD!
    Scars are a reminder to the old of all the dumbshit they did while young - Me
    Aug 2006
    NW Ohio
    1,043
    its on my frame and i want a different color
    ATC500AF
    Pa.'s Highest City
    8,058
    If your getting it powdercoated again the guy will most likely beadblast the parts first. just a thought.
    Sep 2003
    Brookville,PA
    1,408
    I know the guy that does my beadblasting hates powdercoating. He says it just turns gummy and won't come off. He uses Aircraft stripper too.
    Pa.'s Highest City
    8,058
    Have any of you guys ever tried stripping a frame by hand? I did and let me just say... it blows! I say pay someone to do it!
    I'm not sure if the frame is powder or epoxy from the factory.. but the stripper (Jasco gel stripper) I picked up from Lowe's worked right quick.. it's just there's too many nooks and crannies to get into so it's a real PITA.
    The guy that just powdered this frame said he blasted it first. so that's what I based my statement on.
    Attached Thumbnails Attached Thumbnails tri z restore 122.jpg   tri z restore 127.jpg   tri z restore 304.jpg
    Sep 2003
    Brookville,PA
    1,408
    I'm with Chris, I stripped part of my '82 250R frame by hand, and he's right it does suck. It went to the blasters the next day.
    Pa.'s Highest City
    8,058
    I did exactly the same thing!
    Nov 2002
    460
    we use a chemical stripper to remove powder coat , its tough stuff the beadblaster wont even touch it , will need to be bead blasted after to clean it up before powder coating
    Mike
    Frewsburg NY
    1,169
    I took my frame to a blaster and he had no problem with it. The frame came out perfect it had a smooth finish
    Mar 2007
    Texas
    5,045
    How much are you guys being charged for blasting? I'm going to strip my ATC 185 to the frame and redo it ground up. I'm just curious as to the costs invovled.
    also anyone know where to get the exact correct honda red they used on the 83 185s atc? or the coloring at least?
    ________________
    https://www.mikesatvfix.com
