Thread: help with bronco
    mean350 is offline Just Too Addicted Arm chair racerJust too addicted
    uniontown pa
    472
    help with bronco
    is it hard to replace the rear leaf spring monts and hangars on a 96 fullsive bronco? they are both rotted clean through and broke free. thanks
    85 honda 350x
    78 honda atc 70
    84 yamaha 225dx
    03 honda cr 125
    57 chevy bel air
    79 shortbed chevy 4 in lift and 35"s
    Jul 2006
    western ny
    3,366
    yea its a pain. the rubber gromits in the leaf springs tend to not let the bolts out without a fight lol. so you will need a impact gun and a torch. take the torch and heat up the spring where the bolt is and when its to the point where the rubber is ozzing out use the impact to back the bolt out. you better be fast too. that is about all the info ive got for ya without seeing it. ive done it the way ive stated on about a half a dozen trucks and jeeps.
    GIT IT RAAAGGGGG !!!!
    uniontown pa
    472
    i need to replace the whole bracket the spring bolts to. it seems to bolt to the frame and then the hangars bolt to that.
    85 honda 350x
    78 honda atc 70
    84 yamaha 225dx
    03 honda cr 125
    57 chevy bel air
    Jul 2006
    western ny
    3,366
    yea i know you are talking about the perches. well man time to bust out the air chizle. its not easy by any means.
