Results 1 to 3 of 3
Thread: Yamaha YT60 Zinger Owners PLEASE Reply
    Sep 2006
    S.E. LA
    700
    Exclamation Yamaha YT60 Zinger Owners PLEASE Reply
    One question, plain and simple. Have you ACTUALLY changed or at least taken out the Pilot Jet that is supposed to be next to the main jet.
    In the carb diagram it is labeled as a #40 Pilot jet.
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    Apr 2010
    Lindenhurst, New York
    17
    I have removed one 4 weeks ago and I used a small regular screw driver. But there is another jet in the bowl and it requires the same screw driver. Yes, I said the bowl. It through me off big time and it was cover in red rock. Which must have been rust from an old steel gas can. electrolysis breaks the rust down so small and it bypasses the filters then rejoins back together and clogs the jets. Especially in small carbs. Try spraying rust penetrant on the jets before trying to remove them
    The screw driver should be as snug as possible to prevent caming out the jet. And try to use more down force to keep that screwdriver from distroying the head of the jet. Because no one likes to drill out screws or jets. Good Luck
    Nov 2006
    Amishville
    119
    I got tired of messing with the carb on mine and stuck on one off of a pocket bike engine. Runs great...
