Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: other suggestions? Help 200x new top end still makes noise sounds like valve noise
    Apr 2007
    Springfield, PA
    889
    no i did not that might be the problem thanks
    My Rides
    1983 ATC200 - U-Haul edition - great mudder - SOLD
    1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
    1987 Suzuki DR200
    199? Go-ped Sport
    It seems like you changed every part in there. Something must be out of spec inside there. Are the cam journals and the head surface they ride in - in spec?
    How about the piece that attaches to the cam on the left side. Isn't that the pulse generator with some kind of advancing mechanism on it? Maybe thats worn out?
    I hate to say it , but if you want it silent and OEM sounding then your gonna have to tear it down again and measure and check every single moving part.
    Apr 2007
    Springfield, PA
    889
    i think its the cam journal it showed a little bit of wear. do you know if they make cam bearing inserts for it? it sounds like valve noise but its not
    My Rides
    1987 Suzuki DR200
    199? Go-ped Sport
    I'm not sure if you can turn the cam journal down and put a needle bearing in it or not...
    Anything can be sleeved or repaired IF there is enough meat on the casting to allow it.
    It may be easier to simply find another head thats in great shape, just be willing to pay 100$ or better for it. Any good machine shop work will run you about 75$ an hour and setup alone takes that long.
