Thread: 200x experts help
    Lucedale,MS
    47
    200x experts help
    My neighbor has a 83 or 84 200x that was given to him but it needs some work.
    he wants to know can the plastic from an 86 fit with no modifications. he wants
    a peppy motor i was thinking a fresh top end maybe high comp! cam exhaust and jetkit. but i can't find a jetkit any help would be appreciated!
    thanks
    wes
    Apr 2007
    Hazel Park, MI
    19
    I just bought a carb that works great and you can get whatever jet you need I will try and find that info for you
    Apr 2007
    Hazel Park, MI
    19
    Don't go High compression on this motor unless you can easily get race fuel
    Jul 2006
    western ny
    3,366
    ok jetting depends on what kinda exhaust and other mods are done to the engine. you dont need race fuel to run 10.5:1 or even 12:1 . i run 12:1 piston and rings and i use 93 octain fuel.
    slap a 28mm xr200r carb on there, after market exhaust, cam, some port and valve work and then it will be danm peppy. you may need to gear it too.
    GIT IT RAAAGGGGG !!!!
    Apr 2007
    Hazel Park, MI
    19
    I bought a DG Carb from DG performance specialties. I will let you know when I get it installed how it does. Their number is 714 577 7498
