Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: atc 110 finished
    Bartlett TN
    3,083
    Well you can usually find them on ebay and range around 50-75$ or so. I really like the racks on the 110. I had them on mine and they rocked. I also put 83-85 200x hubs on mine so I could use some nicer rims and different size tires. Nice job and talk with Harlan, to get some stickers and you will be set.
    86-87 Tecate ROCK!
    Apr 2007
    Moncton,NB,Canada
    17
    oh man.. so nice n' clean good job man . real good job
    1983 ATC 200E
    1985 ATC 200S
    1986 Fourtrax 250
    1963 Chevy Impala
    1978 Chevy Cheyenne
    az
    2,029
    Thats a real nice trike, I wish I could talk myself into ordering new plastics for my 200S.
    mgenest is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2007
    NH
    204
    Well I have finally been breaking in my atc and am having a problem with the carb. The trike runs fine for a while then after a while it will stall if I give it gas. It will idle fine but I can not accelerate for about 5 minutes, then I can accelerate. I am sure it is my jet setup? This is what I am currently running. Brand new stock carb, Cobra exhaust and a cone air filter. Jet size I am running is #82. Do I need to get a bigger size? Also, I have the clip on the needle right in the center, I have tried to move it but it seams to run best in the middle. Any input would be greatly appreciated.
    Thanks,
    70ATC90's Avatar
    70ATC90 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2006
    Minnesota
    235
    Yeah, i've had that problem too. That can happen with a fresh carb after it is used for a while. I'd just re-jet it and see how it runs.
    1978 ATC 90
    2001 400EX
    Mar 2007
    NH
    204
    Well I took out the #82 main jet and repalced it with a #86 jet. I am still having the same problem? Can anyone recommend trying anything else? It gets frustrating after riding for 15-20mins I have to stop and sit for 2 mins before I cna go again...
    Thanks in advance.
    Jul 2006
    hmmmmm......I just replaced the carb on my daughters 70 becouse of that, but at the same time run into a slight problem, try this take all the air box coponents off, and run open carb, see if it clears up, right now my daughters 70 will only run with no air box, indicating that it needs to be richened up some, also on the same note, go ahead and put a new plug in, try to use a NGK in whatever size that the machine needs
    florida
    2,328
    id check the coil or something ...it may not be a carb problem....
    Mar 2007
    NH
    204
    I have no air box. Cone filter right off the carb. And I just replaced the coil with a new one. I will try the plug next.
    Thanks,
    Maine
    466
    Quote Originally Posted by mgenest View Post
    Does anyone know where I can get a rear rack for this rig?
    Thanks,
    Just wondering if you still wanted that rear rack that I have???
    1987 200x
    1987 Big Red
    1986 250R
    1986 Tecate
    1986 Tri-Z 250
    1986 Big Red
    1985 Polaris Scrambler
    1985 KLT 160
    1985 Tiger 250
    1985 Big Red
    1985 Big Red
    1985 250sx
    1985 70
    1985 225 DX
    1982 185s
    1983 110{Red}
    1983 110{Blue}
    (2) 1977 ATC 90
    1971 US90 Red
    1971 US90 Parrot Green
    1971 US90 Blue
