Thread: 70 axle bearing help please!
    Nov 2006
    Amishville
    119
    Need some advice on changing bearings on my 70. I've got it down to the bare axle and the brake drum. What's the next step to get the axle out? I figure the brake drum has to come off; just not sure how to do it. Any help would be greatly appreciated. Thanks!
    PA
    3,515
    if you got the axle nuts off you just have to slid the drum off the splines....but it might be rusted on so a torch might be handy
    WWW.HREATV.COM
    Phoenix, AZ.
    6,719
    Take the wheels off and then the big collars that slide over the axle. Everything just comes off after that. When I did mine not long ago I didn't realize those collars weren't part of the axle so I was stumped for a minute too.
    Nov 2006
    Amishville
    119
    Thanks, guys. The drum does look to be rusted on. I had heated it up with the torch, so it may be time to bust out the air . Does the axle come out to the left, or either side?
    Phoenix, AZ.
    6,719
    Either side once you get the sprocket and brake drum removed.
    Nov 2006
    Amishville
    119
    Thanks, !
