convertible?
i was going to convert my new cr250 to a trike, but after reading everybodys posts along with not being able to ride a trike in carolina adv. park im having second thoughts!
is it possible to make a bike to a trike and be able to convert back fairly easily? this is the only way id make a "new" trike.
There is actually a kit from missle engineering that turns the atc250r into a Big wheeled 2 wheeler. That would be about the easiest and since it is a bolt on kit, could be converted back and forth if you really wanted to take the time. It would have the small fat tires of the trike. Hope this helps. Just do a search for "Missle" towards the top of the page.
talk to speedbump if you want to see a CR conversion
//ArrowChat Integreation Code
