I think this could be funny.
In my case, 2003 Mercedes Benz SL 55 AMG
http://www.youtube.com/watch?v=SkEG0W1Kgxw
Specs:
engine AMG Supercharged V8
displacement 5439 cc / 331.9 cu in
power 355.0 kw / 476.1 bhp @ 6100 rpm
top speed 250 kph / 155.3 mph (LIMITED)
0 - 60 mph 4.6 seconds
position Front Longitudinal
valvetrain SOHC w/3 Valves per Cyl
bore 97 mm / 3.82 in
stroke 92 mm / 3.62 in
compression 9.0:1
hp per litre 87.53 bhp per litre
torque 700 nm / 516.3 ft lbs @ 6250-4500 rpm
drive wheels Front Engine / RWD
body / frame Unit Steel
front brakes Internally Vented Discs w/ABS, Power Assist & SBC
f brake size 334 mm / 13.1 in
rear brakes Internally Vented Discs w/ABS, Power Assist & SBC
r brake size 300 mm / 11.8 in
front wheels F 45.7 x 21.6 cm / 18.0 x 8.5 in
rear wheels R 45.7 x 24.1 cm / 18.0 x 9.5 in
front tire size 245/40ZR18
rear tire size 275/35 ZR 18
steering Rack & Pinoin w/
f suspension 4-Link Strut Suspension w/Coil Springs, Shock Absorber, Stabiliz
r suspension Multi-Link w/Coil Springs, Shock Absorber, Stabilizer
weight 1820 kg / 4012 lbs
wheelbase 2515 mm / 99.0 in
front track 1553 mm / 61.1 in
rear track 1545 mm / 60.8 in
length 4499 mm / 177.1 in
width 1812 mm / 71.3 in
height 1275 mm / 50.2 in
transmission 5-Speed Auto
gear ratios 3.59:1, 2.19:1, 1.41:1, 1.00:1, 0.83:1
final drive 2.82:1
