Air cooled R wont start
We just got this 84 r.It has been rebuilt top and bottom.It has 170-180 lbs compression.The stator has been tested by the honda manual and timing rechecked..So has the coil.The ground wire is sitting on clean bare metal.We have swapped reed cages,swapped out carbs ,they are clean.Swapped plugs.Check the pipe for clogs.This thing starts runs for maybe 5 seconds and dies.It sounds ok when it runs.The manual says you cant test the cdi with a regular meter so Thats the only thing left.I dont think i have another one to swap with it unless a 200x one would work.Anyone else have any ideas.
85-70,79-110,79-110,80-110,86-250ES,85 250r,86 350x,82 250r
