Has anyone else bought a DG Exhaust for their tri-zinger, and noticed the head pipe hole isn't cut correctly to mount up with the head? If so, can you tell me how you got your DG head pipe to fit right? After taking mine off I noticed the pipe hole isn't really cut right, and I can't use my stock gasket with it.
Today I dropped the motor, FINALLY got the intake off after having to drill the 4 phillips head bolts.
I am going to install the boyesen reeds. But now I don't what to do about the exhaust. I have the stock exhaust soaking in seafoam in case I have to end up using it.
I know one other member on here that had the same problem w/ the pipe mounting right and am waiting to hear from him to see what he did.
