Results 1 to 9 of 9
Thread: How to break in a NEW engine!?
    Mar 2007
    Williamsport, PA/Lycoming county
    829
    I was wondering what the best way to break in a new engine would be. I have read this http://mototuneusa.com/break_in_secrets.htm and it makes sense, or should I follow the user manual for the break in?
    My Stable:
    2007 ARCTIC CAT DVX400
    07 Kawasaki Ninja 650R--My Baby--
    Honda 200M with a 200E engine and 200S front end- A true stump puller SOLD!
    Scars are a reminder to the old of all the dumbshit they did while young - Me
    Apr 2006
    Crestview, Florida
    2,429
    2 or 4 stroke?
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    For my 2 stroke I ran 20:1 Honda GN 2 stoke oil for 3\4 tank of gas.
    I started it, gave it 1/4 to 1/2 throttle blips, not keeping RPM's constant util it got to operating temp. Let it cool down all the way down by sitting for a few hours, re-torqued all nuts and bolts on head, cylinder and exhaust.
    Second time I started it, was blipping throttle to 3/4 throttle until it warmed up all the way then took it for a ride blasting throttle again to 3/4 going through the gears.
    I then ran the gas almost all the way out, drained remaining gas out, replaced plug and replaced with Amsoil Dominator 40:1 mix.
    Did a plug chop to double check jetting and mix and has been running great since.
    Did my top end rebuild about this time last year and rode it in snow, dirt and sand. Only thing I screwed up on was I replaced coolant with a 50\50 premix and was riding in snow and the top tank on one of my radiators was frozen and did not know it until I stopped for a break. Did not do any damage and did not overheat.
    I ended up putting in a 60/40 mix and took care of problem and seems to run a lot cooler in 80 degree weather.
    Just a reminder, no matter what you break in being a 2 or 4 stroke, make sure you have a good constant airflow such as a fan if you do breaking in with no load, sitting in garage, etc.
    1980 110
    1982 250R
    1985 200s
    1985 250R
    1985 350X
    Parting out...
    1983 250R
    1984 185s
    PM me for parts
    Mar 2007
    829
    Its a four stroke and i'm in the market for a quad, most likely a 2007 suzuki LTZ400.
    My Stable:
    Simple... Ride it easy, mostly 1/4 throttle with some 1/2 throttle and vary the gears - let it cool and do it again.
    Then little bursts of 3/4 throttle - let it cool and repeat.
    Then bursts of WOT - let it cool do it again.
    Log about 3 or 4 hours on it with that procedure and toss in a couple of oil and filter changes and RIP IT UP!!
    2 or 4 stroke, same crap........
    Mar 2007
    Mukwonago, WI 53149
    36
    Wouldn't two strokes vary a lot more from 4 strokes?
    I mean... What about touching the power band and all that crap?
    '85 Yamaha Tri-Z
    '89 Yamaha FZ-750
    Missouri
    99
    Its a matter of letting the piston get mated to the cylinder, nothing more.
    Proud owner of a "cornfed" polaris 500 scrambler. . . 4X4
    Coming soon Ninja/mojave/dune buggy, three wheeler
    Visit www.tecateconnection.com for tecate info and to find out whats going on in the tecate world!
    Utah
    644
    I'm sorry, but that article is a lot of B.S. Play it safe and go the tried and true way of breaking it in slow with the manufacturers recomendations. If you noticed at the bottom of the article it also stated that just about everything we do to our trikes is "bad", such as advanced timing, jetting!!!???, ported and polished!!!, flatslide carb!!!
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
    Missouri
    99
    Ya that artical is pretty comical. I wonder what company paid him to "say" that.
