Results 1 to 7 of 7
Thread: I am going to kill somethin
    Apr 2007
    pittsburgh
    52
    Exclamation I am going to kill somethin
    got bike, timing chain broke then had it rebored then, now the cdi i believe is bad kind of learning as i go. thought it was a bad ground sparked real sparadicly. rewired the whole bloody thing. i am not sure if on off switch wires should be wired together or separitly (on off switch is no more) and or rear brake light wires need to be attached to something any help would be great thanks
    Nov 2002
    Kirkville, NY
    3,831
    What machine? All the ones I have seen have the kill switch where when the wires are together they kill the bike (shorts it out), when the leads are disconnected then the bike can run.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jul 2006
    wow! i totally couldnt understand anything you just typed! slow down a bit man! the on/off shouldnt be wired together ...sparadicly usually means the stator is on its way out, thats how my es did then it finnaly died.
    Apr 2007
    pittsburgh
    52
    Exclamation i am going to kill things again
    ok sorry very frustrated, 1984 honda 200x, 2 wires go to kill switch. kill switch has been removed. solder wires together or keep them seperate. i don't know what to do. think cdi is bad, but do not know for sure. was sparking every once in a while. have the book but somethings i understand some i do not. sorry gettin a little frustrated/depressed/rage thing going on over this thing
    Ontario, Canada
    457
    calm down, your questions are answered in the last thread you started on this topic
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Aug 2005
    Portland Or
    412
    take a deep breath, a shot, and a beer...It could be worse...you could have a yamaha.
    "Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."-Ernest Hemmingway
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by TtownJoeShow View Post
    Which one of the 3 or 4 threads was that? ( Sarcastic comment ).
    crazyratt, I have merged a few of your threads together. You will get better answers if you keep everything into 1 thread so others don't have to read umteen different threads to see what you have or haven't tried. I would sugest reading the replies in your first thread about this. And then check out / try some of the idea's that has been put out there already.
    Also, I am closing this thread now. Use the original one.
    Howdy
