ATC70 tech question:
what kind of amperage should I get when I test the hot wire to my ignition coil?
My test light shows there is juice getting to the coil but there is no spark- even when i put a new coil on- so i am thinking the juice from the stator is weak.
batt voltage.use a multi meter to see how many volts you gots.i quess your bike
uses points?check them.if not i hope it aint your cdi.ouch
Most likely your points are dirty or have gone bad. To get to them you have to pull the flywheel.
Howdy
//ArrowChat Integreation Code
