Gearing up causes overheating??
Hey... just like every other teen in the world, i'm out to prove my parents wrong... i just got a 14 tooth sprocket for my 86 200x.... its got 20in. rear tires on it now and it did have a 13 tooth sprocket in the front... my dad says that the bigger sprocket will make the engine overheat because it will be running lower rpms which makes no sense to me... wouldn't the lower rpms with the same speed as the old sprocket revving high let more air go across the fins, causing it to cool off more and its not running as hard so it wouldn't get AS hot??? hope you all understand me but i'm pretty much asking, would higher gearing cause a trike to overheat easier????
thanks
86 200x
72? US90
79 ATC70
83 ATC70
84 ATC70
