Thread: Rebuilt the YTM200 and runs great BUT its so hard pulling the starter cord. ??????
    Mar 2007
    Whitby, Ontario
    137
    Well Here's what happened. When I bought the trike, the guy said its a fresh top end. I have had troubles getting it to idle. She would run but would not idle. Last week, it blew up. I took it apart on the weekend and found that the piston and rings installed were 0.020 undersized to the bore. I opened up the spare engine that came with the trike and found a wiseco piston and rings in it in great condition. The piston size was a standard at 67.00mm. The bore on the cylinder was 0.005 over 67.00mm. So i moved the cylinder, piston, rings,connecting pin, and c-clips over to my engine. She runs with lots of power, idles like brand new.
    My problem now is trying to pull start this thing. It feels like its on the verge of hydraulic lock. When it is idling though, I can hear a small ticking sound. Could I not have enough head room for either the valves or the piston perhaps, or is this common to have this much compression with a wiseco piston?
    By the way, when I do pull the starter cord while shifting over the decompression lever, she would pull really easy. I still have to buy and install the decompression mechanism in the starter casing. I'm on the verge of pulling my arm out of my shoulder socket. Any ideas?
    Yamaha YTM200K 1983 (1)
    Honda ATC200 1980 (1)
    Honda ATC200 1983 (1)
    Honda ATC200M 1984 (1) No Motor Yet!
    Honda 250R 1985 (1)
    Yamaha 2005 660 Grizzly Special Edition
    mark38090's Avatar
    mark38090 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Hawthorne, Florida
    354
    Mine is the same way without the decompression lever. I actually dislocated my 2 middle fingers trying to do it that way.
    1984 Honda TRX200
    1985 Yamaha 200ERN ( two of these now)
    1985 Honda 250SX
    1991 Suzuki LT230
    2003 Honda Rancher 350ES
    Sep 2005
    central Illinois
    651
    yeah, i think the decompression lever has to be hooked up. I tried to start mine once without and it about pulled my arm off now it starts with little or no effort. the ticking sound might be the rocker arms, did you check them for proper clearance?
    Nov 2002
    Kirkville, NY
    3,831
    Sounds like your pull starter is worn out. Take the pull starter off and see if the pulley is loose on the center post. Mine was a bear to pull over but when I switched to my brothers pull starter it there was a huge difference (I am running the wiesco piston too). My pulls tater was worn out big time, I have replaced the pulley but the center post on mine is worn as well so it is still a little harder to pull then it should be, but it is much better then when the old pulley was on there. Now just to hook up that compression release so that the starter won't wear out on me...
    As for the noise, it could be that the valves are out of adjustment or that the rockers are worn. With a 20+ year old machine a little noise is not a surprise.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
