Thread: Compression TEST - Result's are in !
    Oregon
    2,471
    Question Compression TEST - Result's are in !
    I just did a Compression Test ...
    1984 Honda ATC 70 - 4 Stroke
    Result's - 120 PSI
    I warmed up the motor , choke ON & OFF , Throttle WIDE OPEN !
    What do you guy's think ?
    Is it time for a re-build ?
    rustyhondas's Avatar
    rustyhondas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Missouri
    319
    thats fine for a used motor.
    Utah
    644
    MY '81 200 runs at 120 psi. Its supposed to be 154psi +-14 but I'm 5280feet above sea level, so that makes a little difference. Personally I think its an ok compression. Its when it gets like to 90psi you should start thinking about rebuild. IMO.
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
    Mar 2007
    Texas
    5,045
    if you rebuild it, look at a 90 bigbore kit! more powa and stuff.
    ________________
    https://www.mikesatvfix.com
    Oregon
    2,471
    Any one in here with a ATC 70 Manual , What does it say for Compression Range ?
    Post Up , if you have a ATC 70
