Thread: stripped bolts and screws
    massachussetts
    35
    i have several rusted and stripped bolts and screws on my trike and i need to get them off but i don"t know how to get them off. Any help?
    rides:
    1985 honda 250sx
    1985 honda 250es bigred
    both have seized engines from sitting any help would be appreciated i have tried letting it soak with solvents did not work
    Aug 2005
    michigan
    125
    well first try to spray lots of wd40 on em then take a drill and drill it alittle then take a punch and hit it into the center then take a small open end wrench and try to loosen it
    83 atc 200
    86 lt250r quadracer
    Sep 2005
    FL
    855
    cut slits in the screws so a flat head can fit in the. Spray the hell out them let em soak. Then try using a impact screw driver(the kind you hit with a ). If that does not work I would move on to left hand drill bits, then if that doesn't work I would use easy outs.
    "In a society that tries to standardize thinking, individuality is not highly prized." -
    -- Alex grey
    Sep 2006
    S.E. LA
    700
    What I do is use a small drill bit and drill the center, then tap in a TORX bit and using a ratchet, break them loose. Works great.
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    Frewsburg NY
    1,169
    drill a small hole and use a easy out. After you get them out go buy yourself a tap set. retap the holes and you should be good as new. oh dont forget to use ALOT of never seize.
