Got some new rear bearings today,should I shim the axle so it is a tight fit in the bearings or leave it ? The axle is approx .005" smaller than the bearings but I can't see any wear on it.
Honda Atc110 1982
Thanks Brian
Honda Atc110 1982
Thanks Brian
might be the wrong bearing. there shoudl not really be any play in the bearing and axel fitment. Talk about viberation and stress fractures!
________________
https://www.mikesatvfix.com
i don't think i'd worry about it, if it gets any tighter it will b a real pain to put on...thats an eighth of a millimeter (1/8mm) 0.125mm))
'85 ATC 250R
FMF Fatty & Power Core
Boyesen Rad Valve
38 PWK A/S
K&N w/PF (next purchase)
LSR +4 Axcaliber axle
LSR Duel row bearing carrier
DuraBlue Anti-fade (to be installed)
13/36 sprockets
'85 ATC 250R
Parts trike (maybe future build?)
my 110 was/is the same way
