Results 1 to 3 of 3
Thread: 85 250SX - Engine bogging - Need Help!
    May 2007
    NJ
    Unhappy 85 250SX - Engine bogging - Need Help!
    I'm having a problem with my 85 250SX. It always starts right up and idles fine. When I push the throttle past 1/4 it begins to bog and will stall if I don't let up. It has a new plug , clean carb and a clean air filter. Any suggestions?
    Thanks,
    Jim
    Sep 2006
    S.E. LA
    700
    Are you using a fuel filter from the tank to the carb? Those jets can get clogged very easy. How long have you had this problem?
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    springville, PA
    6,185
    I can almost gaurentee if you rip the carb off again the main jet will be plugged.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
