On april 21stwe made our annual spring trip to silver lake dunes in Michigan expecting to have a great day. Well everything went great for about 15 minutes. Then just cruising in 3rd maybe 1/4 throttle my tecate suddenly siezed. Couldn't believe itSo when i got home i took it apart to find it looked really lean on plug, inside exhaust, and even on dome of piston. Mind you i had a 52 pilot, stock needle in middle grove and a 190 main on a brand new 38 keihin A.S. carb. Plating was hurt a bit in the process so i had it re-plated again, and of course all new top end components. Got it running last Saturday after i pressure tested the crankcase, and then reversing things and vacuum testing. All was well in that dept. This engine is fresh from the cases up. So then i went riding slowly for about two hours and still noticed some pinging in the low to middle under very little load, "which is where it siezed". So i went to a 55 pilot, raised the needle, and threw in a 210 main. A bit better but still pinging in the transition from pilot to needle, but pulled the main very very fast and clean. So i then checked cylinder pressure and was shocked to see 189psi. Did it 3 times with two different gauges and dam!
This after i had the head squish band altered and more volume added to reduce psi's to roughly 175. So i have ordered a richer needle to clean up the eretic mid throttle due to it being very lean there and now will mix with VP C12 fuel. This bike runs extremely well and will only get better here shortly. It's truly amazing the appetite for fuel this engine has and the power it puts out
I am by no means a go fast all the time person, just the kind that loves to roost in the sand with my buddies and occasionally turn the heat up on them. Can't wait till next time.
