Results 1 to 15 of 17
Thread: Will a 200watt stator effect performance?
    Phoenix, AZ.
    6,719
    Thinking about putting the light kit from the R I bought recently on my duner. Just wondering if those rewound 200 watt stators have ANY adverse effects on overall performance or not. Anyone know? Electrical is by far my weakest area so I don't have any idea.
    Ontario, Canada
    457
    well it definatly wouldn't hurt performance...you would have to get better spark!!
    i am not 100% sure on this but like 95!
    i want one of them but for my , not sure if there is one for it tho?
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Phoenix, AZ.
    6,719
    I'm not sure it does anything for spark. Just increased output to the lights? Like I said, it's a weak area for me.
    I'm not even sure exactly how the extra power is achieved but figured the extra wattage has to come at the expensive of something.
    Ontario, Canada
    457
    its the extra winds (& proper guage) that give it more juice, i know that for sure...i would try to make my own if my father (retired-Airplane electrician) knew the formula or exactly what it was called..... i guess it would be hard to know if they gave the spark stator more winds...you might beable to tell by just looking at the stock and after market side by side?
    '85 ATC 250R
    Boyesen Rad Valve
    38 PWK A/S
    13/36 sprockets
    '85 ATC 250R
    na
    5,702
    I have one on my shee.It seems to make it run hotter,and the lights are real dim until about 4000 rpm.I do not have the matching flywheel.So that is the reason for dim lights at low speeds.What ever the case,It is coming out this week.
    Proudly NOT a member of
    "Team on the Teat"
    Phoenix, AZ.
    6,719
    This one has a lightened flywheel. Not sure if that would make up the difference or not?
    I'd like to have these lights on my duner but not at the expense of any top end power.
    Jun 2003
    englishtown NJ
    2,676
    it has no effect on power of the motor, just the power of the lights.
    Mar 2007
    Texas
    5,045
    Bwight wights! *giszmo accent*
    ________________
    https://www.mikesatvfix.com
    Newfoundland
    5,280
    Sounds like your Duner is in for a couple changes. That lightened flywheel should improve your holeshots.
    Man I need to move to Arizona, I want a duner.
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    0.15 of a hp gone if the coil is fully loaded...
    Jun 2004
    hayward, ca
    17
    the 200 watt stator will not affect the top end of your motor,it is not a moving part and it does not rob any power from your spark because they are two different coils..the lightened fly wheel is going to make your top end hit faster and harder but you will lose some of your bottom end as a result of the lesser weight.your going to be wide open anyways right those lights are sweet.I wish I could get my tecate stator wound for more power.
    ---DAWG
    85' 350x
    86' tecate
    85' 250r
    gravelord is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Hillsborough,NJ
    300
    where do you get those baja lights for 85-86 250rs? i want a set.
    Phoenix, AZ.
    6,719
    My lights came from Ricky Stator. Not listed on the web site so you'd have to call.
    Aug 2002
    Jamul, CA. near San Diego
    1,605
    is it effect or affect?
    Phoenix, AZ.
    6,719
    Quote Originally Posted by mymint87 View Post
    Actually I think it should have been affect in in the subject but not in the message.
    Will the stator affect performance?
    Will replacing the stator have an effect?
    I think that's right but I'm a moron.
