Results 1 to 12 of 12
Thread: Various ATC90 questions
    It's a 78 model, trying to cosmetically restore it! Anyway, first of all, are the fenders fiberglass? They're obviously not normal plastic and someone told me they were probably fiberglass...need to know so I can buy the right paint for it. Are the rims 2-piece? I took the 3 bolts out of the rim once it was off the hub, and I'm wondering if it's 2-piece and seized up or what...and finally, what would this bike go for in good all around condition?
    Apr 2003
    3
    yes they are fiberglass and if the bike is in good shape it could sale on ebay for a good $$ do you have any pic of it and the rims.. i can help you if you did
    I'll take some tomorrow, but since the tire is dry rotted i'm gonna cut it off and look at the inside of the rim good...
    Nov 2002
    1,189
    yep, their fiberglass, although my 79 110 is plastic. the rim shouldn't be 2 piece, as far as i know, other wise ther would have to be a seal in between the two rims
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Are there two sets of bolts inside the rim. On a two piece rim, there are one set of bolts for the hub, and another set to hold the two halves of the rim together. I belive that a 78 ATC90 came with two piece rims origionally. The other way to tell is to check all the text on the side of the tires. Just about all tires say "Only for use on one piece (or two piece) rims" on the sidewall.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Nov 2002
    1,189
    ok, so my 110's rims are 2 piece, and my 90 rims are 1 piece. that clears me up...
    My Rides
    Yamaha 200E
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by plkmonster2
    plkmonster2, The atc90's all came with 2 piece rims stock. The only ones that didn't was the 70-74 models. Those had the 1 piece tire and rim balloon tires. Your 90 must have aftermarket rims.
    The fenders should be fiberglass.
    The resale value on the 90's can varry. The 1970 thru 1974 will bring more than the later models in the same condition.
    Restored it should be worth between $600 and $1300.
    Thanks
    Howdy
    Nov 2002
    1,189
    i dont think it is aftermarket. I have silver 79 110 rims and they are 2 piece, they have 6 bolts. my 90 rims are the ones that came with it. they only have 3 bolts. they are white, and i have no clue on the year of the 90. i will try to post a pic soon. the frame # on the frame is atc90-1306753
    My Rides
    Yamaha 200E
    Nov 2002
    1,189
    its a 74...... the 90 is a 74
    My Rides
    Yamaha 200E
    Nov 2002
    Auburn Washington
    799
    If the rims on your 90 are on piece and white, they are not the stock rims.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    85 350X (the best)
    Nov 2002
    1,189
    the 90 is a 74. i have seen several other 90's with white rims that are 1 piece. like howd siad, 71-74 are 1 piece
    My Rides
    Yamaha 200E
    Howdy's Avatar
    Celina, Ohio
    10,079
    iF It's a 74 it came with a 1 piece balloon tire and rim combo. The tire size will be 22x11x3.5
    If the rims are 8" rims and are 1 piece they are not stock. No atc90 had 1 piece 8" rims from the factory.
    Howdy
