Does anyone have a stock rear brake line off an 85/86 250R they can measure? I need the total length, end to end. Thanks!
Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
Wife's Ride - 2009 Polaris RZR 800
Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
got sand?
I have a stock one here that I measured for ya, and from eye to eye, I got 25 1/2 inches.
One piece at a time. Status: The Beast is Done..06-23-07
Back in the saddle again![]()
Currently owned rides:
My sleds, and.........
1995 CBR600F3
1976 Kaw 400 triple-smoker......SOLD
1986 250R...owned since 1990
06-23-07........the R is finally done!!!
ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
Thanks InPiEcEs, now to clarify, from eye to eye I assume your talking from center to center of each banjo bolt hole, correct?
got sand?
Yes, that is exactly how I did it. I used my old stock line, and measured center to center.
Are you planning on aftermarket brake lines?
If you plan on going to a stainless braided line, generally, they come as the line only,and the fittings are seperate Each fitting adds about an inch plus to it, so if you bought a line, you would buy a 23 incher, and with the fittings bolted on, it would be 25 to 25.5 inches.
1995 CBR600F3
I'm extending my swing arm 4" and need the correct length line. I'm currently using a SS line that is not the exact same length as the stocker and I wanted to make sure what I get will fit perfectly. Thanks again!
got sand?
