Hi I have a new question,
I just got this big red and have now have put a rear end in it. That is working great btw.
My new problem is starting the machine; When I go to start it it acts like it isnt choking. If I choke it it starts for a second reved pretty high then dies. If I try to start it not choked it takes a while to even kick over, then it will barely idle till it gets warmed up.
Once it gets good and warmed up it runs pretty good, the only thing I notice wrong is a dead spot when you drop the throttle. If I rev it normally no dead spots or very little.
My dad said the hesitation when I dropped the throttle was not uncommon on the bikes, and the hard start was problably the enricher circuit probably not working since it starts and runs great when it gets warmed up.
He is making me fix this thing on my own so I took off the carb, cleaned it well the choke seems to be working well and all passages are clear.
Here is what I have done, any other ideas would be great.
* Cleaned the air filter and lightly oiled it
* New plug
* Cleaned the tank inside well, it had rust and crap (alot of rust was in there)
* Cleaned the petcock and screen filters in there
* Cleaned the Carb
* Added new gas (after I cleaned the tank)
* Checked compression (160 pounds) Doesnt smoke or anything when its running
How does one check if the enricher is working right? I am at a loss there. And if it is the enricher why does it run high only a few seconds then die?
Again thanks in advance for any help, Josh
86-87 Tecate ROCK!
