Thread: help now please...
    Mar 2003
    5
    help now please...
    without the tool...is there an easier way to tighten the chain on an 84 250r trike?
    I hate saying "I got It That Way"
    No Pain, No Gain!
    President of Untamed Offroad
    84 250r
    83 185s
    86 200x
    85 yam 225dx
    Jul 2006
    well.... some tools will be needed, lossen the alen head bolts remove the center bolt spread the housing apart alittle with a screwdriver in between the alen head bolts then with a long 3/8 extension and a hit the notches on the right side to lossen or tighten, then after you get the chain where its tight for you, tighten all the bolts back up and ride out!
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    If you do not want to on the notches, then stick a screwdriver or pry bar through the holes in the sprocket into a notch on the carrier. The carefully roll the trike forward or backwards and the carrier will move.
    Tighten everything back up and you are good to go.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Aug 2005
    HI
    1,575
    what will make this method even easier, is if you make your ho's to do it for you!
    Rest in peace Rex Carlson
