Results 1 to 15 of 15
Thread: Has anyone ever used a sealant in place of a gasket for centercases?
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Like threebond, Yamabond, etc?
    if you talkin a honda..250R it needs the gaskit because it acts as a shim for the internals.. the cases will squeeze too tight on the internals and tear it up..
    Live Oak, FL
    15,069
    I thought about that right after I hit the post button. Probably needs the thickness from the gasket for all the gears and stuff to align.
    Newfoundland
    5,280
    I use gasket maker on the Tecate case halves as they require no gasket.
    Charles Town, WV
    1,316
    I can't offer any suggestions as far as needing the gasket as "shim" but I know Honda manual transmissions on cars use Hondabond between the halves of the cases to seal from the factory and after being split and repaired. (at least they did on all the years I worked on them)
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    the Rotax cases use hondabond or yamabond no gaskets made for them
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    I don't care for the sealant alone theory. I'm repairing a 2000 KX125 as we speak that is leaking from the center case. I can't find any case flaws or damage, I guess the kawabond failed. I'd much rather have a gasket.
    Were you just in a hurry with no gasket on hand or why did you want to use just sealer??
    Live Oak, FL
    15,069
    pretty much Dirtcrasher. I was just curious that in the event of I had to re-assemble without a gasket because I didn't have one, if it would be plausible to even try it.
    Apr 2006
    Crestview, Florida
    2,429
    You'll be fine if you let it tack up first, then hand tighten and let it set for an hour or so before applying torque. BTW Threebond is a great product.
    Oregon
    2,471
    Love the ThreeBond !
    Jul 2003
    indiana
    892
    I am a believer that gasket maker is no replacement for the actual gasket but in a pinch it'll work. My buddy and I rebuilt his crf450 and used yamabond on the case halves and it worked fine for about three months. Started leaking again but this is on a race only mx bike. If ya have to do it it'll work for ya.
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    If it has a gasket, I would use one.
    I'm willing to bet that the clearances are set with the gasket, at the proper torque.
    Some machines simply use sealer, like a lot of sleds.
    I think I would play it safe and get the gasket.
    For places that require sealant, I agree with Erics350X. I also like the Threebond stuff. It's never failed me.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Mar 2007
    Texas
    5,045
    Quote Originally Posted by 350Xhilaration View Post
    still do!
    ________________
    https://www.mikesatvfix.com
    he has one comeing in the mail
    Columbiaville, MI.
    1,508
    Billy ,I personally would'nt suggest it for a long term solution,reason being,I just completed a 250X quad motor,when I split the casses the gasket material was all over the lower unit,it even worked it's way to the clutch side and by the oil pump port ,and was loaded with that crap down by the screen,thus oil was restricted ,wasted the head and the piston blew up inside like a grenade,which I think the culprate was the sealant..I know the R motor is different than the 250 thumper motor ,but I am just telling ya what happened on that particular motor..
    MDR Racing
    LONG LIVE SANCHEZ RACING
