Results 1 to 15 of 20
Thread: trike not running (trobleshooting)
    Mar 2007
    Howard Beach, New York, United States
    687
    im starting to give up, i dont know what to do. recntly i bought a carb off a 200x and put it on my bigred, thinking that would get it to start, but i have had no luck, so im trying to figure out what it is. the only time i get it started is if i put gas in the plug hole and pop start it, then it turns over, drives a short distance and dies. i cant figure out why the engine wont get gas.so im going to list my possib;e problems and maybe someone could tell me if thats whats wrong.
    -vacume hose for fuel line
    -old oil
    -mufffler gasket missing
    -only have header pipe on
    -when using electric start bike makes poping sound, soundslike it wants to go, but it wont (http://www.youtube.com/watch?v=yZf_lxq6UQ0)
    possible soultions
    -new fuel hose
    -towing bike to start
    -new oil
    -air fliter
    -muffler
    -replacing piston and valves ( oh i hope not)
    i just really need some sort of comfirmatin, a little hope that its something simple keeping my bike from running, if anyone as an idea f whats wrong please tell me, i just need something to ride, and if i cant get this trike runing by july im selling it
    Current Project:1978 Pontiac Phoenix 355 v8
    Past Bikes: 1999 Yamaha Big bear 350, 1981 Yamaha XS 400, 1996 Yamaha yz250 1984 Honda big red, 2004 Xtreme cr107, 1999 Yamaha bear tracker, 1999 Suzuki ds80 STOLEN, 2005 Kawasaki klx110, 1986 Honda trx200sx
    Daily Driver: 1990 Buick Electra Park Avenue 3.8 v6
    Apr 2006
    PA
    1,464
    Could possibly be the piston or valves. Or else its fouling plugs?
    Aug 2006
    NW Ohio
    1,043
    if you hear a popping sound cam chain may be loose and out of timing but in just enough to run for a short time.
    ATC500AF
    Apr 2006
    Crestview, Florida
    2,429
    Check the compression just cross that off the list. If that checks out ok i'd say it 's the 200x carb/fuel problem. Have you checked/cleaned the petcock?
    Oregon
    2,471
    Make sure your fuel lines are clear , or replace them.
    Check the Filter in the Gas Tank .
    Check the vent in the fuel cap is working .
    there might be a Screen filter also on the Carbuator , ( My ATC 70 Does - 4 stroke )
    Sep 2006
    S.E. LA
    700
    All great replies. Maybe the popping sound is from a plugged header pipe. Run your finger or a rag in the open end of the pipe and if there is a lot of black carbon. If so the pipe could be plugged. What happened to the muffler?
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    florida
    2,328
    the petcock is new he got a new one off me ...and the carb was tested and working before being returned....im thinking valves or timing dude...if it started that one time it has enough compresion to run
    Mar 2007
    Whitby, Ontario
    137
    If its back firing, you got some timing issues. Make sure the timing marks line up. When it dies, do you check your plug? is it dry, wet, or soaked. If its wet, your loosing spark, if its dry, your loosing fuel, If your soaked, your carb is flooding out your engine. Have you changed to a new plug. Ive had bad plugs right out of the package for my cars before. Keep at it buddy. Don't loose hope. This is why its fun.
    Yamaha YTM200K 1983 (1)
    Honda ATC200 1980 (1)
    Honda ATC200 1983 (1)
    Honda ATC200M 1984 (1) No Motor Yet!
    Honda 250R 1985 (1)
    Yamaha 2005 660 Grizzly Special Edition
    Mar 2007
    687
    well im positive it is getting gas, the question is how much gas, i check the plug and it is usually black but not soaked unless i put gas in the plug hole. spark plug is great almost brand new, i just checked the spark, and it definately burns gas. muffler even gets hot just trying to elec start it. muffler has a bunch of holes in it, and the back of it is plugged, so i figured might as well take it off, reason i kept the 200x jets in the carb is because i have no air filter or muffler, and when i dop get both, it will be higher airflow, so im one step ahead
    Mar 2007
    Whitby, Ontario
    137
    You shouldn't have a black plug. It should be brown in colour. I had a sparkplug that would spark when I check it out of the engine and cranked it over. As soon as fuel came into contact with it, it didn't work at all. I threw another new plug in it and went riding. Have you checked the gap on your pulse generator. This acts like a distributor cap on a car engine. I just had somewhat of a similar problem on my suzuki sidekick. It would run for a while. but as soon as it gets really hot, I would loose ignition. What happened is the cap and rotor was fouled up good. When it got too hot, I would loose the gap between the rotor and cap and would loose spark to all my plugs. It would only happen when it got too hot. You could also have a faulty pulse generator or your ignition coil is starting to go on you. Check that gap first and go from there. Good luck..
    Honda 250R 1985 (1)
    Mar 2007
    687
    thanks, actually thats what i was hoping, that it is something with the pulse generator or coil. i just want a definate answer so i know what i need to do, hopefully i can take the bike to my cousin so he can fix it
    Apr 2006
    Crestview, Florida
    2,429
    have you checked the flywheel key.
    Mar 2007
    687
    no i have not, is it something i can do with the right fender still on? (bolt is stripped, pissin me off)
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    Alright, do the following to narrow down your problems
    make sure your getting spark
    make sure your getting fuel (wet/dry plug)
    do you have compression
    Check your timing, i dont know where the peep hole is on the hondas but on the yamahas its a cap on top of the stator cover. While you have the cam chain exposed, make sure its tight to eliminate the chance of it jumping time. Also check the cam sprocket and chain for wear.
    Sometimes these motors shear the flywheel key, so pull the fly wheel with a set of pullers(dont try and beat it off with a ) and check the keyway.
    Check and recheck your carb settings and clean the carb spotless
    Ill almost put money on it that its the timing if you can get it to run for short periods of time, or that it isnt getting or is getting to much fuel.
    Try those things i listed above and get back to us.
    Mar 2007
    687
    i got spark
    plug is wet
    yes it has compression
    timing is the hard part, i cant get the peep hole cover off, and the cam chain tensioner requires the engine to run in order to adjust it
    idk how to check the flywheel
    il definately check the carb
    would vapor lock cause this?
