Results 1 to 13 of 13
Thread: help with 250R kill switch
    Apr 2007
    maine
    23
    im having trouble hooking up a kill switch to my 1984 250R.......there is a couple of loose wires at the front of the wire harness......tan, light green, and black......ive tried black and green but no luck...i also got zapped with i pushed the button while the engine was running and while it was hooked up to the black one....thanks for the help.
    Attached Thumbnails Attached Thumbnails 3wheelerwires 001 redo.jpg   3wheelerwires 002 redo.jpg   3wheelerwires 003 redo.jpg   3wheelerwires 004 redo.jpg
    1984 Honda HRC ATC250R....DG pipe.........first 3wheeler ever owned
    Oct 2005
    saratoga, ny
    2,819
    check out the home page. they have all the wiring diagrams on there. that should be able to help you out.
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    I'm not sure on the 84, but on the 85 and 86 R it's a Black/White wire, and a Green wire.
    When these two are connected, it kills the engine by grounding the ignition.
    One way to find out is to remove your engine stop/headlight switch.
    Follow the two wires off of the engine switch, and you got 'em.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Nov 2006
    epsuh
    56
    I've got the same problem I baught a kill switch and buld it on but when I have the kort on the engine dousn't run and when I pull the cort of it runs so I have the opposite of what is supposed to do
    grtz: Stefan
    one act250r from HOLLAND
    Apr 2007
    maine
    23
    "buld it" -stefan34...........i cant understand what your saying..................and InPiEcEs.....mine dosnt have the factory light/kill switch thing.....someone took it off, what you see in the pics are what i have to work with...and the kill switch is only a single wire switch
    Nov 2006
    epsuh
    56
    jep I am gonna make some pic of it after my exams sorry for my bad englisch I come from holland
    InPiEcEs's Avatar
    Apr 2004
    Northeast Wisconsin
    378
    The switch has only one wire because it grounds when you mount it.
    On most of the diagrams I looked at, it is either a Black, or a Black/White wire off of the CDI that must be grounded to kill the engine.
    On your diagram, it is the black one. Since it looks as though someone hacked the wiring up some, you might have to trace the Black wire off the CDI.
    The Black wire you had hooked up might have been the right one, but the switch might not have had a clean ground, and that's why you got wacked.
    You might have to take one of the handlebar clamps off, and clean up the handlebars right there so it gets a better connection to ground.
    Also, if your bars are painted, sometimes you have to scrape a little spot of paint off so the switch grounds good.
    1995 CBR600F3
    Apr 2007
    maine
    23
    wow, thanks.....ill have to try that handlebar trick...mine is painted black.
    InPiEcEs's Avatar
    Apr 2004
    Northeast Wisconsin
    378
    Good catch John. I didn't catch that.
    I'm used to the ones that ground to kill.
    You would need a switch that is normally closed (connected), and I will bet the one that you have is normally open (disconnected).
    You would then hook the Black off the CDI, and the Green that goes to the headlight,taillight, and CDI from the mag (stator) to the switch.
    When you go to kill the engine, the switch would be disconnected, and run would be connected together.
    1995 CBR600F3
    Apr 2007
    maine
    23
    yea mine is normally open....so hook it to the black one in my pics and the green one i had it connected to in the pics?
    Apr 2007
    maine
    23
    so i tried scrapping the handlebar down to bare metal, and then connected it to the black wire, and it worked...any way to keep the bare metal from rusting? thanks.
    Apr 2006
    Crestview, Florida
    2,429
    lithium grease or clearcoat
    Nov 2005
    New Jersey
    659
    On the 85-the green is for the headlight/tailight correct?I know on some other 85 models the green is ground, not on these machines right?What light is for the high beam on the 85?Blue?
    http://www.pilotodyssey.com/PO/index.php
    88 TRX LRD,39MM pwk,Durablue+4.Nice rider
    85 250r West Coast +4,Durablue +4,Boyesen rad valve,Keihin 39mm,Rad double row carrier
    86 250R west coast +4,Durablue+4,Maier plasitcs, Keihin, Boyesen,Wiseco big bore kit
    85 350x-all new everthing,trailer queen,all OEM-NOT FOR SALE!!
    4-FL400R HONDA PILOTS.See my section on the page!
    2-85 T-3 Tecates all the bells and whistles
    85 T-3 project trike in works
