Results 1 to 8 of 8
Thread: Any ideas on how to remove this?
    Aug 2006
    Texas
    997
    Im trying to replace the rear bearings on my 200M. As with everyones, the brake drum is giving me hell. Ive beat the brake drum off in pieces, and am left with this metal part. Ive tried grinding along one side as to relieve the pressure and hopefully loosen it up, but it seems it extends all the way into the seal where the grinder cant get. Any ideas how to remove this? All I have to work with is an angle grinder, drill, and . No torch or anything. Thanks!
    84 Honda 200ES Big Red
    Jan 2005
    Great Bend
    704
    take it to a cutter and have them cut it off. I'd spend $20 or so just to get rid of that headache. Once it's out you can start from scratch with a replacement axle and brake drum.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Oregon
    2,471
    Soak it in PB BLASTER , Then keep grinding with a small grinder.
    Take Time .. But should be ok
    ontario canada
    64
    your all most there grind the other side too and beat it off but not to hard and use some lube.i had the same problem but i got it off.good luck
    Jul 2006
    iowa
    451
    yea like honda 4h said, grind the other side too. then maybe try chiseling it off with a big and a chisel where the grinder cant get to.
    air grinder two grooves on each side allmost through it as close as you can to the axle, then take a sharp chisle and break it in two
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    Die grinder with a cutting disk.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Jun 2006
    Niagara+SouthRiver ONT.
    132
    Grind some more then get out the
    BFH and a chisel
    85 Honda Big Red 250 es
    85 BMW 318
    67 Chevy C10 383 M21
