i believe youhave to remove the cam and hang your timing chain to the side with a string or wire so as to not drop it in the motor. then remove the complete head, cuz i believe the studs would get in the way of you dropping the head gasket down because they run straight thru the cylinder and head and you have 4 nuts and washers that go on top of the head cover/valve cover. so yes you will have to remove your head to do this.
