Okay, trying to fire the Z up for the first time, and I have a few questions/concerns.
The fuel pump pulled the fuel up to the pump from the reserve hose fairly quick, but I had the petcock in the on position for a long time before realizing it. The fuel trickled towards the carb after turning to the reserve position, but doesn't really seem to be gushing anywhere's enough. I pulled the plug after the first few dozen kicks, just to save my energy. I later found a small leak that appears to be coming from the bowl on the fuel pump. Would this be enough to keep fuel from running to the carb?
Does the spark plug installed help build vacuum in the carb? It seems it might take forever to get the float bowl filled at this rate!
I filled the radiator, and it took about 3/4 of the gallon jug, and hasn't really moved much after kicking it over a few more dozen times. Does everything fill up just by pouring the fluid in? I wouldn't think so, but this is my first waterpumped bike, so it's all a guessing game for me! I later found that the head gasket is leaking a little. That's a good sign that water is flowing! I didn't put any silicone on before assembly, only because I didn't find anything in the manual. I wanted to, but also didn't know what it would hurt if some got into the water jackets. I'm running a YZ gasket that came with a kit I bought for the '83 YZ head and cylinder. This is a fiber gasket with a metal ring in the center. I have a Tri-Z gasket that is 3 metal disks, but couldn't find anything that noted top or bottom on it.
I'm not even trying to actually fire it yet, at least until I get the fuel filled on the carb side of the pump. I have the bottom fuel hose from the tank going to the bottom fitting on the pump. Any tips/tricks/suggestion/comments worthy of a new Z rebuilder? Tomorrow could be the big day, if I get these issues resolved. Uggggh, I hate the idea of pulling the head, because I imagine I will have to drain the radiators first, just because the hoses are so cramped in there!
