Results 1 to 7 of 7
Thread: Necessity of Reservoir Tank?
    Sioux City, IA
    256
    Sorry for all the post lately, but I'm on the home stretch of this project. Actually the faint odor of paint curing on brake parts is wafting out of the oven at this very moment. Anyways, '85 250R that didn't have an overflow tank when I bought it. How important is this item to have? Are we talking major capacity comprimise or merely a little green stuff in the dirt?
    "Trikes don't kill people. I kill people."
    www.250r.us
    Sep 2005
    central Illinois
    651
    i have older cars without an overflow and no problems so I wouldn't think it would hurt anything. But...the cooling system is of pretty limited capacity so it would be nice for some added assurance
    Sioux City, IA
    256
    Yea, new Honda tank and parts is around $40. I got too much in this thing to take any risks.
    www.250r.us
    Oct 2005
    west.wa
    68
    I dont run one.. Ive never had a problem overheating. I just took the hose that goes to the overflow and aimed it at the back side of the pipe, if it overheats it will steam.
    May 2007
    Coshocton, Ohio
    1,815
    Actually the overflow tank plays an important part in the cooling system. If your engine overheats and coolant is forced out of the radiator and goes into the overflow tank it will be pulled back in to the radiator when it cools back down. If there is no tank it just spills out and is gone. If you lose too much coolant on a long ride you could end up screwing up your engine. I would say if it came with one it would be wise to keep it on there.
    Feb 2006
    Texas
    738
    Very true what Daddio said. But I've had most of my machines without the reservoir tank and there has been no problem at all. What I mean is that it will not cause any harm to not have one. Having one, if it overheats, will save the coolant/water for later use, if it does not spits out of your sistem.
    Hope this helps
    TORKER.
    THOSE WHO SAY IT CANNOT BE DONE, SHOULD NOT GET IN THE WAY OF THOSE BUSY DOING IT...
    Las Vegas, NV.
    2,532
    Quote Originally Posted by torker View Post
    It won't cause any harm as long as you consistently check the coolant level & refill as necessary before each & every ride. Otherwise, you'll eventually find yourself starting out on a ride with a coolant system that only contains about half of it's necessary capacity.
