Results 1 to 7 of 7
Thread: CR 480 crank the same as CR 450?
    Jan 2005
    Oklahoma City, OK
    603
    Hi I was wondering if the crank out of an 81 CR 450 is the same as the crank from an 82 cr 480? Thanks!
    85 Tecate, 2002 Honda 300EX, 83 & 84 250R, a bunch of honda 4 strokes from 90 to 200cc, a klt 110, ytm 200, polaris 250 cyclone, '05 Roketa 125 (cheap chinese pitbike to beat on), '69 Scrambler 6x6, and a 52 John Deere B (hey its a rowcrop narrow front, that counts right? )
    Trike Fest 06 and 07 Survivor, hoping to make it to 2010
    the 82 480 is a 89x76mm bore/stroke I cant find nothing on the 81cr hope it helps..
    Nov 2006
    southern oregon
    2,338
    They at least share the same stroke as the 480's...the 450 is 85mm x 76mm...
    2-stroke lover
    might be like the yamaha from that era ,,all used the same crank,465,490,500
    Jan 2005
    Oklahoma City, OK
    603
    Thanks guys, I guess they are different, they both have different part numbers, although I have heard of situations where this was not the case. as in, same part different numbers. I guess I have to fork over the extra cash to do it right thanks!
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by Chevy200s View Post
    Remember... Identical and interchangable are two different things... they may just be weighted differently... You might check the interchange on the bearings and primary gear... I think the flywheels physically interchange, and I know the 480 piston fits on the rod... I bet the 450 crank is lighter... If so...just weight match the pistons for correct balance....the 450 was known for having a lightswitch powerband...unlike the mellow 480...
    2-stroke lover
    Oct 2006
    Utah
    64
    Man I should be able to answer your question after having owned about 10 480's and 450's, but I think old age is creeping up on me
    Good luck though, and thankfully 480's arent on the endangered species list (yet) so I'd probably just find a replacement 480 crank and be done with it
    1985 Honda 350X
