Results 1 to 14 of 14
Thread: Help please ! 250 sx swing arm removal.
    Jul 2006
    I am attempting to remove swingarm to replace pivot bearings and u-joint on shaft to be ready for the Haspin mud. I have factory Honda shop manual, and special lock nut tool. Right side lock not and bolt are out but can't slide it sideways enough to get left side out of frame! U-joint wont go sideways enough to allow this. Do i really have to remove axle and rear carrier first? Can i remove the front transition cover and pull the gears apart there? I am stumped. And Honda doesnt sell a u-joint. Are these readily availiable? Please share some info so i can have my mud buster ready for TF. Thanks for the input. T3 Lopes
    DONT TOUCH THAT COVER!!!!!!!!!!!!!
    Just gently pry back on the front driveshaft yoke, it's on spring forced splines. It will slide back and the swing comes off kinda crooked. OR, just remove the back axle, unbolt the diff and remove the driveshaft. Thats the best way to do it so you can inspect, grease and service everything....
    GLUCK!!
    Jul 2006
    Thanks for the info Dirtcrasher. Whatever it takes I will get it done. Do you have any info about replacing the u joint? Thanks lopes
    Jul 2006
    Thanks John , let me know. Lopes
    Quote Originally Posted by T3 LOPES View Post
    Hey bud, I have to believe that there is a manufacturer that can provide us with a u-joint by now... But, a good EBAY shaft is the way to go. Look for a clean ATC with a nice black diff and if the shaft journals are shiny - GRAB IT!! That joint doesn't wear much unless water gets in there, in which case you will see pitting, scoring and lots of surface rust.
    I've since found the love of my life - not a woman of course... But a 350X and sadly the 250SX is just a bench now. I love it and it has it's place but I'm just not into the SX as much as I was years ago.
    But... I know them inside and out so if you need any other help, ask away.
    Jul 2006
    Thanks alot John . I wiil let you know when I get it apart tomarrow. Lopes
    Yep, thats not an SX driveshaft, BUT!! It's a good example of the quality your looking for - SHINY SHINY!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    t3 I have a bunch of the sx and es drive shafts also if you need 1
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    Jul 2006
    Thanks Dale I will let you no. Lopes
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    I have a SX drive shaft setting on the bench in the gurage. I do not think the U-joint can be replaced easily. After the caps were pressed in at the factory, the peened the holes to hold them in. I think you are going to have to find a whole shaft assembly.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Quote Originally Posted by ATCnut View Post
    I agree, they use some type of fixture and press that surrounds the outside are with a pressed in notched type hold. I wouldn't just peen over a new one.
    BUT, My previous thought was to machine an inside groove just like a piston circlip in each bore to hold a replaced joint in place. A milling machine and boring head could make short work of that, setup would be a pain but it could be done.
    Jul 2006
    Thanks for all the Info guys. I am headed in the right direction. thanks again.
    Jul 2006
    Took it all apart last night and checked out the u joint, it is still in great shape . Bearings were screwed. Changed the bearings out and everything else so shes ready to go . Thanks for all your help guys. Lopes
    Nov 2002
    Auburn Washington
    799
    COOL!!!
    Ride Red!
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    85 350X (the best)
