Thread: Quick carb question?
    Apr 2006
    PA
    1,464
    I got my 200x to idle real good now, but as soon as you give it some throttle and let off it stays reved up in the lower RPMs for a minute?? Would this be it running too rich or too lean, and what would need to be adjusted to correct this?
    Apr 2004
    Brigham, Québec, Canada
    1,528
    humm!! may be your throttle cable is stuck somewhere????
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Apr 2006
    PA
    1,464
    Hm, your right? I never thought of that. Its a pretty new motion pro twist throttle, but you can adjust them in a couple places. So ill check that out? I never would have guessed that could be the problem.
    Utah
    644
    My Bw does the same thing. I give it gas and then let it off and it will sound like it almost bogs down for a few seconds. I wouldn't use this as a sure sign for running "rich" or "lean", but in my experience it has always happened from running a little rich.
    oops...I reread you post and it sounds like are bikes are 180 degrees from each other. Yours revs up and mine boggs down. Maybe its running a lean then??? BTW I love your color scheme on your trike.
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
