Results 1 to 12 of 12
Thread: highest octane recomended for 250r
    May 2007
    lancaster,ca
    125
    so what would you recommend
    the guy i bought the bike from told me he put a high compression piston in my bike and a larger carb but i really dont believe him other than i can tell the top end is from an 81-82 250r and i have an 83
    it has a red head and jug on a black block
    so who knows
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    It wouldn't be a high compression piston..........maybe a reshaped head or something. I would run premium pump at the least.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Apr 2007
    I use turbo blue 110 its great stuff.
    Phoenix, AZ.
    6,719
    It depends on how much compression you're getting. I run 100LL aviation fuel. Works great for me.
    May 2007
    lancaster,ca
    125
    im getting 130psi with a compression tester and the tester had a slow leak
    Aug 2002
    New York
    1,098
    you can run 87 octane with that compression.
    lower octane = more power.
    I run VP C12 but I run 225lbs compression
    Apr 2007
    The manual for the 81-84 recommends using 92-100 octane leaded fuel, also the compression pressure should be 156 + or minus 14 psi.
    May 2007
    lancaster,ca
    125
    ok and the compression is read by how many kicks?
    and i also did it on a cold engine i know its supposed to be done on a warm engine to get proper compression
    Apr 2007
    England UK
    27
    Depends what sort of gas the ignition timing is set for,or are you going to set the ignition timing to the type of gas your going to use !
    2 atc 70's (well ones a 160 now)
    1 atc 110
    1 atc 125
    Just bought another 70 well minus forks and engine!
    May 2007
    lancaster,ca
    125
    well i just figured out that i dont have the right carb and i know by looking at the mauals for the 85-86 250r and 350x that i dont have thos either
    so o dont know what i have and what floats to order
    also i did the compression check wrong as i stated before i did it cold and i also forgot to open the throttle wot so it is higher than i stated
    Mar 2007
    Minnesota
    102
    What about for the average 4-stroke 200cc trike? I have always wondered what I should be putting when I fill up... My trike is ALL STOCK.
    Any thoughts?
    Sep 2005
    Lipetsk, Russia
    2,824
    Quote Originally Posted by _brad_ View Post
    Any thoughts?
    Regular pump gas.
    I'm back in the USSR...
