well if it wont restart till it cools off it could be the coil is going bad. its all ive got for ya.
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
take the cdi cover of the top of the motor and check that the rotor/timing advance mechanizim there is a little pin that keeps this aligned correctly that can fall out if not tightened correctly and the symptons your are talking about sounds likely that's the issue. you will have spark and will get gas and it will pop and try to start once in about 20 kicks I've had 4 200x machines do this as they was not tight enough too stay put Loc-tite will fix this use the blue not the red for easier removal when neccessary
Trikes currently owned
E.T. trike 150H.P. and climbing Pure DRAG beast
85 250r project
hey dale sounds exactly like the problem
Erectordale could be onto something. The small pin on the camshaft fell out of my 200x. Blue Loc-Tite did the trick. Also, it still could be your valves not adjusted correctly. A friend of mine used to work at a Honda dealership years ago. He said you would not believe the people that brought in 200x trikes because they wouldn't start. Usually, one of the mechanics would grab a large adjustable wrench and feeler gauges and hop in the back of the truck, adjust the valves, and fire it right up - without even unloading it. He said the 200x and the ct70 engines are the pickiest when it comes to valves needing to be adjusted perfectly. Check 'em again to be sure, hell it only takes a few minutes. May save you a lot of time and aspirin. Let us know what you find!!! You have some curious watchers here.
I'M GETTING TOO OLD. IT TAKES ME AN HOUR AND A HALF JUST TO WATCH 60 MINUTES.
'85 Big Red 250es (Beer truck)
'85 350x
'85 250r
'84 ATC70
'01 Yamaha Warrior 350
'05 Honda Recon 250
Always looking for more!!!
'05, '06, '07 TF survivor. Looking forward to '08!
hey i have um both at .007 is that about right?
no the book calls for .003 i believe.
I don't know the specs off the top of my head. Dale probably does. I'll see what I can find...
'85 350x
'85 250r
'84 ATC70
'05 Honda Recon 250
If you have them at .007 and the book calls for .003, you're 5 minutes from firing that puppy up!!!
'85 350x
'85 250r
'84 ATC70
'05 Honda Recon 250
anyone kno where to get the bent feeler gauges...i broke the .007 one trying to adjust them at that weird angle!
yea i hear ya i broke mu .003 off in the top end lol. i dont think you can buy angled ones but i could be wrong. go out and adjust them valves to .003 man. git it rag !!
i just checked the book it .005 =] so i gotta do that and then try again lol...thx for the replies
00.5 ? dam mine tells me 00.3 ooo man im confused now. grrrrrrrr maybe thats why mine ran like crap. stupid books!!!!!
i have a clymers and an official honda...clymers .003 honda .005 im sure honda is right
ok valves adjusted...now on choke it spits fuel out of the carb?? any body around ft myers wanna come take alook ? before i buy a lifan motor and say screw it
the valves burnt or not in time .... i dunno ?
"07" DR650 Suzuki Dual Sport
