Results 1 to 7 of 7
Thread: sprocket question
    Jul 2006
    western ny
    3,366
    sprocket question
    will a sprocket off a 84 250R bolt onto a 85 200x sprocket hub ? also if i want speed i want a smaller rear sprocket dont i ? im thinking of running a 12 or 14 front sprocket. i know the engine will turn it no problem.
    well within the next week i hope to have a rolling chassis. it all depends on when my parts start coming in.
    GIT IT RAAAGGGGG !!!!
    Sep 2005
    Lipetsk, Russia
    2,824
    Yep, less teeth in the back = more speed.
    I'm back in the USSR...
    Apr 2006
    PA
    1,464
    If the 85 is the same as an 86 yes and no. I have a sprocket off a 250r i believe. You have to grind down the back of the sprocket to fit the little washer thing into the groove. But yes it can be dont, i used a 15 tooth for mine.
    Jul 2006
    western ny
    3,366
    you used a 15 front tooth ? dam howd it work for ya ?
    Apr 2006
    PA
    1,464
    I love the 15 tooth. I have 20'' rear tires and the rear sprocket is a 38. Its alot better than the stock 13/38, and theres still plenty of power to go anywhere.
    Sep 2005
    Lipetsk, Russia
    2,824
    Sounds like the 200X was undergeared from the factory.
    Either that or that Pro-Circuit pipe actually DOES something!
    Apr 2006
    PA
    1,464
    Well yeah it was geared way to low stock. It did fine with the old cobra too but it does seem to have a little more torque now. Though it could be my imagination it really does seem to have a tiny bit more power now that i rejetted it and got a new filter and all.
