Results 1 to 12 of 12
Thread: 350x bearing carriers
    Columbia
    5,131
    Are the bearing carriers the same from 85 to 86?????
    God I hope so......
    Columbia
    5,131
    Anybody-anybody?
    Apr 2007
    Springfield, PA
    889
    well, since no one answered you ill chime in, i think i heard people on the board here saying that their different, but im not 100% sure, i dont know 350x's, check with someone else.
    My Rides
    1983 ATC200 - U-Haul edition - great mudder - SOLD
    1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
    1987 Suzuki DR200
    199? Go-ped Sport
    Hampton, Virginia, C.S.A.
    2,664
    the bearings are the same...the carriers are different
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Mar 2003
    Barnesville,Ohio
    2,298
    yes...the carriers are different. you can use an 86 carrier in an 85 but you have to use the 86 rear sprocket and bolts. the 86's are countersunk to clear the carrier. the 86 carrier is also the same as a 250x/300ex.
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Back in Happy Valley
    833
    The easy way to tell them apart is an 86 has 4 (i think) holes in it for the axle adjustment about the right size for a .25" allen wrench, and the 85s have the old style tooth adjusting ring on the left hand side. Either one will fit in either years swing arm, the 85/86 calipers mount differently, the 86 sprocket is a large diameter mounting bolt circle than the 85. The 86 sprocket is chamfered and runs a 'flush' bolt head instead of the std style bolts on the 85. I'm sure there's more but with a little effort you can make anything go together its just the details...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    Columbia
    5,131
    Anybody have an 86 carrier for sale!!!!???!?!?!?!?!!??!!?!?!?!?!?!?
    Good god Im in a pinch!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Apr 2006
    PA
    1,464
    Theres a few on ebay for 119 shipped for an 86. Look to be RAD carriers?
    http://cgi.ebay.com/ebaymotors/250x-...spagenameZWDVW
    Columbia
    5,131
    Im not going to deal with ebay right now, not dependible enough to get parts in time.
    Nov 2005
    New Jersey
    659
    I might have 1 for you,but it comes with the swinger as well.I'll let it go for cheap.
    http://www.pilotodyssey.com/PO/index.php
    88 TRX LRD,39MM pwk,Durablue+4.Nice rider
    85 250r West Coast +4,Durablue +4,Boyesen rad valve,Keihin 39mm,Rad double row carrier
    86 250R west coast +4,Durablue+4,Maier plasitcs, Keihin, Boyesen,Wiseco big bore kit
    85 350x-all new everthing,trailer queen,all OEM-NOT FOR SALE!!
    4-FL400R HONDA PILOTS.See my section on the page!
    2-85 T-3 Tecates all the bells and whistles
    85 T-3 project trike in works
    Columbia
    5,131
    Going to TF????
    Columbia
    5,131
    Are there any other bearing carriers that fit the 86 350x?????
