On my 200x it came with an aftermarket rad carrier with the tapered bearings that were pretty loose when I got it. I just ignored it and rode it for a while then noticed that the bearings were lose and put a small spacer between the sprocket and bearing to take out any play. That fixed the problem for a little while now its doing it again!. The jam nut is fully tightened and will not press the disc in far enough to tighten the right side bearings? What is causing this to happen? I dont want to put another spacer in and end up with a ruined axle/carrier? Is this a common thing with these?
