Results 1 to 7 of 7
Thread: new clutch questions
    hazard's Avatar
    hazard is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2007
    Iowa
    162
    hello all, just bought a ebc dirt racer clutch kit for my 350x, it contains the friction discs, pressure plates and heavy duty springs., my question is if i should use the heavy duty springs or just use my stock ones, my clutch pull is fairly easy and smooth right now with a stock clutch i assume., i was kind of wondering how much harder my clutch is going to pull with heavy duty springs?
    Thanks,
    Adam
    ______________________
    1985 ATC350X
    -86 engine and plastics, DG rcm full exhaust, DG grabbar, Moose Carbon Bar, Moose bark busters, UNI air filter, Regina chain, ECA rear brake caliper, 22x11x9 Maxxis Razr 2 tires
    1984 ATC250R
    -Project trike, needs top end rebuilt
    Sep 2005
    MICHIGAN
    2,027
    Compression springs experience load loss with use, meaning they dont last forever.
    The heavier springs may be harder to compress but your clutch plates will engage better.
    86 T3
    84 T3
    86 KX250
    dont forget to soak your clutch plates in oil for a hour before you put them in!
    Charles Town, WV
    1,316
    I'd recommend buying new OEM Honda springs if you don't want the harder pull.
    I put new fibers in my X a couple years ago and got new Honda springs. Engages fine and pulls like original.
    I've heard those heavy duty springs are really stiff to pull. Unless you have engine mods (quite a bit more power, not just a pipe and air filter), I would not advise going with the heavier springs, especially if you like the easy pull of the OEM.
    hazard's Avatar
    Mar 2007
    Iowa
    162
    do they seriously pull that much harder than oem, i mean they cant be that much stiffer can they???
    Thanks,
    Adam
    1985 ATC350X
    1984 ATC250R
    Charles Town, WV
    1,316
    Sorry, I can't help with 1st hand experience with that question. I've only heard of guys complaining about the stiffer pull after putting in "heavy duty" springs.
    they do pull a little harder but your clutch hand get use to it real quick!
    I run RTC easy pull levers so I cant tell the difference
