Results 1 to 11 of 11
Thread: 1985 ATC 250R Swingarm and Axle
    hoser's Avatar
    hoser is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2005
    ILLINOIS
    284
    What other trikes or quads will a 1985 ATC 250R Swingarm and Axle interchange with ?
    Thanks in advance,
    hoser's Avatar
    Nov 2005
    ILLINOIS
    284
    Anybody?
    Someone has to know..
    Jul 2006
    trx 250r axles, 450r swingers with everything 450r in them (axle and carriers) can be slightly modified to fit, umm.... I think thats about it.
    hoser's Avatar
    Nov 2005
    ILLINOIS
    284
    Ok just to clarify a 85 ATC250R swingarm assembly will fit onto a 86 TRX250R ?
    Thanks again.
    Jul 2006
    ummmmm... not sure on the whole swinger
    hoser's Avatar
    Nov 2005
    ILLINOIS
    284
    Ok thanks, I never followed the parts interchange too close hopefully someone that does (Trike Yoda) will see this and reply.
    Aug 2006
    Salt Lake City, Utah
    71
    will the 85 250R swingarm fit on an 84 200X
    Aug 2006
    NW Ohio
    1,043
    the 85 swiner is the same as 86/87 other than how the rear brake caliper mounts.
    ATC500AF
    viper's Avatar
    viper is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2007
    milan missouri
    215
    and it uses a different carrier
    350 stock cyl drag banshee
    85 yamaha tri-z stretched and powered by a SPROCK RACING big bore on alky baby ..yes its fast and no you cant ride it ...lol
    86 atc 250r
    86 350x
    ????? who knows what else ?????
    and if you want to take donations i will stay home !!!!
    NASHVILLE
    514
    Aussie knows which ones interchange. He used a TRX swinger on his 85-86 250r but he had some Cuttin to do
    Current Rides:
    All Red's!
    Jun 2003
    englishtown NJ
    2,676
    I had an 86/87 swinger on my 85 frame, it fit perfect. 88/89 ones will fit also, but it is solid in the center(losing the rear motor mount) and its 1" shorter. I don't know about 450r ones, I know 400ex ones require some modifing.
