I just bought a 1986 250R that hasn't had much maintenance in awhile. I did a search but didn't find anything helpful. I've got two problems: 1. an exhaust leak and a gas leak.
I can't get the exhaust pipe to seat square on the exhaust flange. I've pulled the exhaust several times. I attached the flange to the head and then attached the exhaust. That didn't work, so I attached the flange to the exhaust and then bolted it to the head. That didn't work either and each time the exhaust ends up cocked on the flange and I have a leak. The flange and the exhaust are probably worn, so I'm assuming I have to replace one or both. Do I need that billet aluminum flange, (it's cheaper than an oem flange) or, can I use high-temp RTV?
The second problem is that gas seems to be leaking out of the overflow tube when the trike is sitting flat on the garage floor. Any recommendations?
Thanks!
You're welcome for all the help. I'm an original 250R owner for 21+ years, so I've seen a lot of the things you're going through & will go through. Good luck.
